Loops and canonical polygonal schema
(Anne Verroust-Blondet)
Version française
Index
Description
Results
Publications
 Description
A closed orientable surface of genus g can be obtained by appropriate identification of pairs of edges of a 4g-gon (the polygonal schema). The identified edges form 2g loops on the surface, that are disjoint except for their common end-point. These loops are generators of both the fundamental group and the homology group of the surface. The inverse problem is concerned with finding a set of 2g loops on a triangulated surface, such that cutting the surface along these loops yields a (canonical) polygonal schema. We present two optimal algorithms for this inverse problem. Both algorithms have been implemented using the CGAL polyhedron data structure. We propose a method to model and control topological changes by a smooth deformation of a polyhedral mesh using curves and loops. As changing the genus of a surface is not a continuous transformation,the topological change is made when an intermediate shape between the two topologies has been obtained. The creation and the deletion ofholes are studied. The deletion of a hole uses non null-homotopic loops to designate the hole to be deleted. A method computing two independent loops associated to a hole is presented.
 Results
 Publications
Contact
Email : Anne.Verroust(@)inria.fr
Adress : Inria Paris-Rocquencourt - BP 105, 78153 Le Chesnay Cedex - FRANCE
Phone : (+33 1) 39 63 54 41
Fax : (+33 1) 39 63 59 95
Secretary : (+33 1) 39 63 53 74
