Next: 2 Installation procedure: UNIX
Up: 1 Introduction
Prev: 1 Introduction
Contents
The minimum disc space required for the installation of MODULEF is approximately 100 MB. On a SUN4 workstation, this space is occupied as follows:
Source code | : | 25 MB |
Makefile's | : | 0.5 MB |
Binary files | : | 50 MB |
These values are merely indicative since they depend on the machine used, the options of compilation options, and the executable files created (it is not obligatory to create all the executables).
The memory necessary to execute MODULEF depends on the problem under consideration. The larger the number of
unknowns, the larger the size of the super-array to be reserved. As an indication, a 2D elasticity problem with
3 600 triangles and 3 722 degrees of freedom ( nodes) requires:
627 487 | words for the matrix, with skyline storage (MUA); |
86 036 | words for the matrix, with compact storage (AMAT); |
7489 | words for the RHS vector (B). |
This problem was solved by a simple conjugate gradient method (one D.S. AMAT and one D.S. B) with the
following configurations:
Minimal conf. | Recommended conf. | |
Central Unit | 32 bits | 32 bits |
Main Memory | 1 MB | 16 MB |
Virtual Memory | 16 MB | 32 MB |
Secondary Memory | 20 MB (hard disc) | 100 MB |
In addition, the MODULEF system requires a Fortran 77 compiler with the following two extensions:
MODULEF runs successfully on a number of computers, such as CRAY, HP/Apollo, IBM RS 6000, SUN, Silicon, HP 9700, Dec Alpha OSF/1 etc.
