Next: F List of graphic peripherals available
Up: Part IV: Appendices
Prev: D.2 Possible problems
Contents
In order that the editor considers each library only once during the resolution of the external references when performing the linking process, the list of MODULEF libraries must be given in the following order:
batc bihm plma conw comp menw cont conv elnl evol trac cosd visu bout flui calc elas reso elcp emc2 menu nop2 nop3 piez resd resr ther ela2 ela3 magn nopo poba resb vis3 resc symo bnf3 lang aloc lisp utsd ft3d p_lMM < List of graphic peripherals > p_genera ft3d u_MM zzzz_mod utii blas_mod u_MM
Note: The variable MM represents the name of your machine in the above listing.
