Next: 1.4 Objectives of the club
Up: 1 The club
Prev: 1.2 Structure of the club
Contents
The MODULEF club was founded due to the need for research tools, knowledge sharing and
the communication of expertise, material means, etc. Furthermore, in the view of:
- the price and specificity of industrial software packages,
- the growing number of engineering problems which are solved using numerical simulation, and
- the complexity and multiplicity of the algorithms,
the researcher has an increasing need of a library of algorithms in order
to be able to concentrate exclusively on new methods and implement them rapidly.
These tools, developed in a modular fashion,
enables researchers to test and compare new methods, and to communicate the results of their research to a
large number of universities and industries (valorization of research). However, considering the volume of such a
library, a huge computer effort is necessary in order to make its use as least constraining and as
adaptable as possible to non-computer scientists.
Up: 1 The club
Contents
