Next: The EMC˛
preprocessor
Up: 1.4 The module APNOPO
Prev: 1.4.4 A complete example
Index
Contents
- COUR
- Definition of the curves present in the domain via a function parser.
- POIN
- Definition of the characteristic points.
- LIGN
- Definition of the characteristic lines from the characteristic points.
- QUAC
- Call the algebraic mesh generator for a generalized quadrilateral.
- TRIC
- Call the algebraic mesh generator for a generalized triangle.
- TRIA
- Call the advancing-front mesh generator for an arbitrary domain.
- TRIH
- Call the Voronoï mesh generator for an arbitrary domain.
- MANU
- Call the manual mesh generator.
- OBJE
- Call the mesh generator for a single element.
- BARR
- Call the mesh generator to create segments from a contour.
- TRAN
- Translation of a given mesh.
- ROTA
- Rotation of a given mesh.
- SYMD
- Symmetry with respect to a line in a given mesh.
- DILA
- Dilation of a given mesh.
- Q4T
- Split each quadrangle of a mesh into four triangles.
- RETR
- Split each element of a mesh into sub-elements of the same type.
- REGU
- Regularization of a mesh by barycentering.
- AIGU
- Remove obtuse angles from a mesh composed of triangles.
- AFFL
- Refine a mesh locally around certain vertices.
- NUME
- Modify attributes (reference or sub-domain number) in a mesh.
- RECO
- "Glue together" two meshes.
- ADPO
- Definition of nodes in a given mesh.
- EXTR
- Extraction of the edges with reference numbers given.
- RENE
- Renumbering of the elements of a mesh.
- RENC
- Renumbering of the elements and nodes of a mesh.
- COUL
- Renumbering of the elements by coloring.
- SAUV
- Store a mesh resident in main memory on file.
- INTR
- Introduce a mesh resident on file into main memory.
- TUER
- Delete one or several data structures in memory.
- IMPR
- Print the contents of a NOPO data structure.
- DESS
- Plot a mesh.
- FIN
- End of job.
Next: The EMC˛
preprocessor
Index
Contents
